A/C fan(blower) relay question
SHOerwin
WALK THE CHALK
Palm Harbor, Florida
Haven't posted in some time, but I have an issue right now that has me puzzled. The relay, or breaker, or whatever it's called, keeps blowing. This prevents me from using the a/c, heater, defroster, vent, et al. Quite annoying in the rain! I haven't put 100 miles on the car since moving to Georgia in May. I have replaced said unit 7 times. Every single time, the fan will work for about 2 minutes before the just-replaced piece expires.
Any clues?
Thanks, Jono.
SHOerwin
WALK THE CHALK
It doesn't run at all. The compressor runs, the temp will show, and even the fan level readout will change as you increase/decrease. But no air will blow out of the vents. I could put another relay in right now, and in about two minutes it would be dead again.
Is the connector where the relay plugs in burnt? I burnt up a relay once running the fan on high in very hot weather.
I see no reason for a relay to burn up unless there is a lot of resistance on the load side connectors. Maybe the wire is loose or corroded at the motor end too. But to burn up the relay would take a lot of amps.
Are you using a 40A relay or a cheap 20/30 amp relay?
SHOerwin
WALK THE CHALK
The part number I have been using is MR76. I have been buying them from NAPA and Advanced. I did the test, and the readout read 888.
I don't know what the amps are on MR76, but my gut is telling me it's 20-30. If I recvd the lower amp relay as a replacement for the factory piece, and used that number for all subsequent replacements, then I've been wasting cash and time.
