97 SHO trans seal
starper57
il
front pump trans seal went out this morning, got maby almost 3 years on trans rebuild, i heard that thay had many changes to the front pump seal, if so what has been the best one, taking it down now, if you can help, thank you.:hail:
SHO#7
Cincinnati
The seal is the same. The stator is changed.
You are going to have to take the transmission apart some to change out the stator.
Sonnax makes the best one. Replace the torque converter too.
Mike
