96 sho engine no compression on one bank
jimljake
richmond va
i have a 96 sho engine complete in my shed.when i took it out it had no compression on left bank all cylinders.still ran.no banging or clunking. what do you think happened? had 95000 miles on it.
Mr Anonymous
Tire Wall
Two words: Cam Failure.
See www.v8sho.com for all the technical details, reporting and such.
Basically, the motor will need (at least) one new cam, 8 new valves/guides/seals, new headgasket and bolts, and time. There's still a possibility of a cracked piston or rod, or worse if a valve head broke off the motor is basically toast.
Satchmoz
