Ha. I get the airbag beeping too. I've ignored it for a while as I don't have time to check if it's just the module or the clockspring. These things are ooold, especially electrically now.
That's the only way to be sure. No driving issues when it flashes?
There is a module (IMRC) that controls the butterflys opening. Can you verify the butterflys closes when you first start the car.
I believe that your (P)ower (C)ontrol (M)odule is OBD-II.I picked up an ODB1 scanner, and no codes were available. I drove it and was able to get a check engine light to come on by hammering the throttle and holding it on the highway, but the light went back off before I could get pulled over to test, and then no codes showed again.
I tried to remove the TPS from both (92MTX & 95MTX), but they didn't budge.
OK, thanks. I'll have to research how to do that.
One thing I noticed is the connector with one wire, a gold wire on the intake, barely has any covering on it. Is this a ground or something and/or should it be fully wrapped?
View media item 708
Thanks for the correction luigisho.No, OBD II started in the 96 models
I think the workaround would be helpful!Thanks for the correction luigisho.
I have the Innova OBD1 also. It works very well and not expensive. You do have to follow directions though same as the paper clip method. It helps if you get the extension cable for a one man operation.
I had a mysterious bad running '91 recently but no codes or flashes. Fortunately I had a known good PCM that I swapped and got the code right away-bad TPS. Installed a new OEM unit and the SHO runs real well again.
p.s. I noticed other posts about the air bag light from **** w/bells lol. I had the same for a very long annoying time.
My mechanic gave the SHO a work around. The air bag system is inactive as it is with a flashing light but there is no flashing light or bells. The SHO runs as though nothing happened.
If anyone is interested I'll get a write up on the work around and post it.
Thanks again,
Best to All.
Joe
If done right, the first thing that will happen is that the fan will run for a couple of seconds.
