Long story short. Yesterday I drove a mile (literally) down to the store, half way through drive back I could hear/feel the coolant popping in the block, looked at gauge, and it was almost pegged. Pulled over and parked it for 2 hours, then came back drove it rest of the way home where it got up to the N in about a 1/2 to 1/3 mile very easy drive. On the drive back I put the defroster on high-fan max heat but it never blew anything but ambient-temp air.
When I got it home I popped the hood, saw no smoke/steam, heard no sizzling, and there still appeared to be some fluid in the reservoir. This morning I go out, it cranks over fine, starts right up, no new or interesting sounding noises. I immediately turn it off, pop the radiator cap, it takes about 1-quart of water and is backing up the filler neck. I went ahead and filled the reservoir up to the mark and then drove it around the block some. It again in less then 1/2 mile began to over-heat and I shut it down and parked it. Again no sizzle or steam or the like and again no heat from the defroster.
So my question is where should I be looking? Bad T-Stat? Bad Water Pump? I am inclined to think it's a water pump because I have no heat inside the car.
All help is much appreciated. Most of my wrenching experience comes from a 5.0 T-Bird and 4.9L F150. The SHO is quite a different beast from those two.
Thanks.
Thanks.
