95mtxsholove
just put new motor in and now getting no spark can u help me out thanks:thankyou:
visual inspection. check and see if it's cracked. if you have a spare swap it in and see what happens.no spark at all and how do i test the dis?
generaly speaking yes, but one guy dicked up his crank sensor replacement and even though it was pretty damaged his tach was still functioning.if my rpms r working my crank sensor is good?
there are a number of people who have removed the stock sensor and installed a gauge sensor in its place and their cars start.I thought if no rpms were present it means bad cam sensor. But, if they are present it usualy means good cam sensor. You. Probly have bad crank sensor, bad coil,m or you computer does not like your car but I still think ground. O yea I think if you do not plug in the oil pressure sensor the car will not start its a saftey feature
