94 SHO a/c vents?
sho_ted
Albany, NY
15 yrs of florida sun before i got my 94 SHO finally did in the center a/c vents, above the radio. How hard are these to change out?
jelloslug
Digital
Greenville, SC
is the bezal hard to remove?
Remove the knee panel below the steering column (4 torx screws).
Remove the two screws on either side of the steering column.
Remove the two screws above the instrument cluster.
Pull the headlight **** off and remove the nut that is behind the ****.
Carefully pull the bezel away from the dash so you can pop the rear defroster, redundant radio controls and the fog lamp buttons out (the push out from behind) and disconnect them.
Remove the bezel.
Satchmoz
