94 or 96 calipers
jayro
Auburn, In
Okay, I read the sticky above and also searched, but didn't find an exact answer. I plan on doing my 96 upgrade with my next break job. I know that all that is needed is the caliper brackets and the rotors (and new pads), but I see alot of people are using the calipers from a 96 as well. Are these calipers superior to my '94 as well? Or is it just easier to get the "Loaded" 96 calipers since they come with the brakets and pad?
Jeremy
Mr Anonymous
Tire Wall
All '94+ calipers are the same.
There were some early SLO calipers with a phenolic piston, but those get steel pistons on rebuilds so they are rare to find.
Storm-Chaser
Shit Louis
What Chris said . . . .
'94 and up Taurus front calipers are all the same. In order to use the larger diameter rotor, a larger caliper bracket for that same caliper must be used. That "96 upgrade" bracket began appearing on Taurus's in 1996 (96-99 SHO / 01-07 Taurus/Sable), as well as other FLM vehicles.
Do a search, there are a number of threads which identify which models and model-years the calipers can be found on . . . .
:burnout:
jayro
Auburn, In
Thanks for the info....I found a bunch of threads with info regarding the brackets, rotors and brak pads to use. I knew that you could use your original calipers, but didn't know that all the 94+ Taurus's had the same ones. :thumb:
Jeremy
SuperHO
Mental Patient
St. Joe, MI
I did the upgrade, and the only thing I changed was the brackets and the rotors. I'm still using pads I bought for my 95 a couple of years ago. I know i'm not getting the full benefit of the upgrade, but hey, the whole thing cost me less than $20. Pads were on the shelf, the rotors came off my 98 a week before and I stuck with the same calipers. Now my baby stops goooooooooooooooood
Satchmoz
