1993MTXSHO
Its a Taurus...
Car is a 93 atx, trans is a 93 with 80,460 miles on it, we just put it in and one of the lines to the cooler is stripped and leaking so we need to fix that. But the car only goes in drive, but when put in reverse it acts as if it is in neutral. Why might this be? Could the leak cause a big enough pressure drop to cause reverse to not work? I need to get this fixed ASAP so any help you can give would be awesome.
TIA
TIA
