93 atx probs
sccasho
kenova, wv
going to work the other day, my car shut down on the free way. everything just went dead. i pulled over and sat for a sec and tried two or three times to start it. nothing, then finally i heard the fuel pump kick on and it started roughly but it ran and got me to work. now it sits in front of my house fuel pump kicks on everyother time but it wont start. thanks byron
SHOfun 93
Euless, Tx (Fort Worth)
Sounds like your fuel pump is on the way out. Listen when you turn the key to "acc" and hear the whine of the fuel pump. If the whine drops in pitch, or seems interrupted, it is time.
JoeHoe_SHO
SHOPUKE
Rochester NY
Check codes...make sure your computer is hooked up right. Check the fuel relay computer(CCRM) near the radiator under the panel(driver side) Fuel filter...could very well be the pump. Just check the cheap stuff before you go and spend $160 on a new pump
Heathcotejosh37
