91 sho fuel pump issue
rit191
Okanogan, Washington
My sho died about 300 yards from home two days ago. Sputtered, regained sputtered and died. I ran codes and got 11, 66,95,66,95. Checked engine shrader valve and zero fuel comes out when reed valve depressed, even when cranking. Grounded out fuel pump test lead and got clicking at icrm, but no fuel pump. Can't hear fuel pump come on when test lead grounded or without. Reset inertia switch, no joy. Tested volts at inertia switch leads: 4 volts with test lead off, and 12 volts with test jumper to ground. No joy when I jumped the switch leads. I replaced the fuel pump about 8 years ago, but less than 20k miles since then. CEL is on. Have spark, have tachometer
Roma steady 500 rpm when cranking. Checked all engine grounds and they are good. Naturally fuel tank is full. Any thoughts? Thanks!
sperold
Last to Know
Tap that thing under your radiator cover (CCRM) where your emission and belt locations are shown.
rit191
Fuel pump toast
Burnt itself up, destroyed the wiring harness on top of the tank, fried the ground. Have replacement Bosch 165lph pump, but no pump guts or wiring harness to hook it to. Anybody know if regular Taurus wiring harness and senders are the same as sho?
myculito
