91+ rebuild
blk\blk90
TX
Ok so I'm doing my semi 120k this weekend. I need to do all this mainly because I just bought the car and have no maintenance records. I need the cam sensor replaced asap. I have the timing belt and water pump to replace. I also have valve cover gaskets, intake gaskets, plugwell seals, plugs, wires, tb gaskets, and a new cam sensor. Anything else I may need to do this job or links to any site will be well appreciated. Thanks guys/gals.
blk\blk90
TX
Also I've been drinking and plan to tackle this tomorrow. So if I don't make sense I will tomorrow. :cheers:
blk\blk90
TX
So "lots" of work started today. Still trying to figure out posting pics so bear with me.
Bringing it to my new house.
20181006 105516
Dirty rear VC vs "cleaned" front VC.
20181019 192641
This is most of the RTV I pulled off the VC and plug well seals. You can still see some on the plug seals. Is this normal?
20181019 192722
Gotta make sure with what you got.
20181019 194438
There she is. Just a peek though!
20181019 194449
Rear dirty VC vs front "clean" VC
20181019 195935
Interior view of previous.
20181019 195959
My new workspace/project.
20181019 210922
Throttle body removed.
20181019 212902
DIS mount. Maybe not enough heat sink stuff?
20181019 213142
blk\blk90
TX
Ewww
20181019 213654
Partial disassembly.
20181019 221314
Full disassembly.
20181019 224404
Time for a cleaning!
20181019 225719
Still a lot of work to do! Most of those part are for the tundra. SHO parts are in the car.
20181019 231519
Do I need any rtv for the VC's? And how do you clean the secondaries? Can you put them in the washer? Cause I'm probably going to...
blk\blk90
TX
The old plug well seals.
20181020 003521
Other side.
20181020 003541
Is this ok? When I said this engine was full of rtv, I wasn't kidding. Do I need to use any? In the corners yeah, but like this? I was scraping that shit out for a while. Until I learned that rtv doesnt like degreaser. Note to self: degrease first.
blk\blk90
TX
After the DW:
20181020 011159
Hmmm...
20181020 011159
Hmmm...
20181020 011227
Looks OK.
20181020 011233
2 minutes with a steel brush on the left, DW on the right.
20181020 011613
Same
20181020 011622
Same
20181020 011650
blk\blk90
TX
I'm gonna put it all back together just to take it all apart again to get it all stripped and powdercoated. But I just want to get this pos running for now.
That's alot more rtv than I ever used. It is needed on the rounded corners where the semi circles meet at the vc and heads. That's it for original setup. I have heard of people using it to get a better seal at the spark plug well seals.
zoomlater
Seattle, WA
Were you going to replace the crank position sensor as well? Unless you know it was a recently replaced item, you might as well since everything is apart. If it is still working, I would keep it as a spare.
blk\blk90
TX
Dear lord, please let somebody be online. I need to get my crank bolt off but I have my intake is off and I'm already at #1 tdc. How do I get this ****** off!?!?
blk\blk90
TX
Do I even need to replace it?20181020 164205
I'm pretty sure it needs it.
sperold
Last to Know
The best way to get the bolt out is to use the starter motor.
Put a socket and short extension on the bolt and put a long bar on whatever is solid and bump the starter.
blk\blk90
TX
The car wont crank. I think because I have everything on top taken off.
You need either an air gun or a way to get a good cheater pipe over a breaker bar or a strong ratchet and correct socket
blk\blk90
TX
I'm gonna change the cam sensor and put it back together. I'm tired of dealing with it. Which way do the intake horns face in the manifold? I'm reading through tons of threads but none say which way they face.
KyngofPop
Freday-day
Charlotte NC
Can you not get the stater to even bump? That’s the most common way to get the crank bolt to break free without power tools.
blk\blk90
TX
It wont crank st all. It has power off the battery with jumper cables. It makes weird noises when I hook it up, but doesnt even try to crank.
