91 mtx fluid fill plug
Adam Berke
Albuquerque, NM
Can anyone tell me or show me a picture of the fill plug for transmission fluid on a 91 mtx? I was under the vehicle and noticed dripping from the transmission. I see the drain plug and above that is where I think the fill plug should be but looks like maybe the previous owner lost or stripped out the threads and tried to use jb weld to plug it. I'll try to upload a picture of what I'm talking about
Irish Pride
Irish Inside
MusicCityUSA
First thing, there is no drain plug. Don't remove anything from the bottom of the trans case to drain the fluid. If you accidentally bump the shifter you'll need to tear open the case to reassemble the gears.
The fill plug is on the front of the case in between the PS cooler and the starter. It takes a 3/8s drive to remove.
-Chad
