89 cobra brake swap
SHOlemon
Nova
Is this swap possible? I see it for later years, but are we SOL? Went racing this weekend and wore into a caliper piston :cool: and another SHO team said they set their brakes on fire several times and did the Cobra swap for better performance and less fuego. Im told that it may invole a knuckle swap, caliper bracket adapter plates, some possible rotor drilling, etc. Anyone know this stuff off the top of their head? Im just starting my research.
Thanks,
OCP Racing
Check shosource for parts list and pricing. Also yes it involves knuckle swap for the earlier SHO's. If you order non SHO vendor drilled rotors then you will probably have to redrill some holes to get the stud spacing correct vs mustang spacing.
rbruso
unlikely
Tucson, AZ
Completely doable. You'll need:
1) 94/95 Taurus spindles. 89 didn't have ABS, so you can get these from non-ABS Taurus/Sable
2) Cobra calipers and caliper mounts
3) Cobra rotors.
4) Cobra pads and hardware kit
Was running a set on my 89 for about seven years before I (possibly terminally) parked her last fall.
For the rotors you can either redrill them to 5x4.25 or just use a Dremel (or similar) and elongate the holes to 5x4.5. It's not really a lot of material to remove and goes pretty quickly.
You will absolutely need 17" wheels. There was one set of 16" wheels that just cleared this setup, but I'd be worried about getting a pebble or other debris wedged between the wheel and rotor.
Satchmoz
