80MM lightning MAF wiring blues, please help
1slickRED89
Guest
Toledo Ohio
I have a problem wiring my OBDII maf in my '94 ATX. I need help lining up the wires.
Since this post I got the coil pack wired properly, but the MAF is still wrong. after a ER code 159, I connected a break-out-box and sure enough I have power where I shouldn't, and not where I should.
this is how the wires are now.
engine harness.....MAF plug
red....................Green/red
Tan/blue............Brown Blue
Blue Red............Black Brown
Black/Blue..........White/Blue
Could someone PLEASE post up the correct orientation of these wires!!!
1slickRED89
Guest
Toledo Ohio
good thing I printed out your post before you edited it. had the signal and ground wire flipped. thanks for the observation and post. the type of MAF it is, is in the title. this would not have been a problem if i had waited for the engine to be in the car first.
That was the '97 SHO that I listed but deleted. The Lightning MAF was different for '97 so I pulled the post content.
If you know what year vehicle it came off of I can get the exact pinout for you.
1slickRED89
Guest
Toledo Ohio
thanks, but that won't be nessisary as I fixed the Problem with your help already. I belive it is out of a '00 lightning anyway.
Satchmoz
