802SHO 2010 Build
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Check-In
I’m excited to test my latest revision Rev21. The junkyard 6F55 has just under 500 miles put on it over the course of 20 tune revisions.
Some very cool functions I’ve learned over the past couple weeks!
-We found the high capacity converter state, learned its directly influenced by crank torque and how to ramp the TCC pressure floor and hold high pressure through upshift torque reduction
-Found a way to pre spool the turbos on the footbrake up to 6psi boost!
-found and edited torque reduction recovery ramp rates
-found a way to disable advance trac and make the pcm ignore chassis slip related torque reduction requests
-mapped gear type and ratio maps to make my own custom torque by gear targets
-we have the Tcase low torque source either completely removed or it’s torque reduction effect removed basically
-made a nasty crack and pop tune
-found additional gates locking me out of 1st gear coupling to eliminate
If it all goes according to plan, I’ll
stall the TC to 3200-3300 rpm for about 3 psi boost, the car will make a max of 400 ft lbs in 1st on the brake and immediately start coupling at 15+Mph, no torque cuts, couple 1st gear through the 1-2 hand off and hit 475 ft lbs and hardlock 2nd gear to single digit TCC slip, couple through the 2-3 handoff and make max 500+ ft lbs and hardlock again under 10 rpm slip, actually have torque reduction for the 3-4, no flar, hardlock again and torque reduction for 5th gear,
No flare and hardlock to 130+ mph. And anything I decel in between 2500-3000 rpm should crack a brief flame and pop.
Rev21 will also use a different set of wheels and tires. Drastically cut scrub radius and may substantially improve stability compared to the wide “look” using fender flares and spacers. May be sacrificing quite a bit for that look.
For now these are coming off. IMG 3122IMG 3131IMG 3134IMG 3136IMG 3137IMG 3141
Can’t wait to find out how much closer it’ll be to dialed in on 93 finally.
802SHO
Ego was brutalized but the car is fine.
Big mishap last night. Car is fine but I apparently needed some humility…
Had Rev21 tuned. Forgot my old 1” wheel spacers actually converted studs to M4 X1.5 and that wasn’t really the issue. The issue is I’m using those aftermarket lug nuts on my aftermarket wheels on my raptor so I didn’t have any aftermarket M14 14 X1.5 lug nuts to use and then I tried to use 2 inch spacers that I had that was 1/2X20, but the center bore of that wheel adapter is larger than my Mickey Thompson wheel center bore so I put my other wheels back on to at least get a feel for Rev21.
My Son was with me and the only other time he’s come with me for a test drive in the new set up was towards the end of last year when the transmission was acting up. We drove about 3 min and turned back around before it died. I was excited to show him my latest tune, and unfortunately, I didn’t check the car over and I didn’t realize that I did not install my hood pins. :popcorn:
I did this once before, but I caught it going about 35 mph when I gave the car a little bit of throttle and I saw the hood move a little bit and I was like holy shit so I avoided it that last time, this time, I didn’t realize I didn’t put the hood pins in until I was going 60 mph on a throttle stab and I saw it starting to lift.
So I had that split second realization that I forgot to put my hood pins in when it was already too late. But what happened next is pretty crazy. Everything I did before this worked together to reduce a lot of damage. I had cut in those three hood vents so it weakened the structural integrity just enough to help fold my hood over the roof. Bc I had deleted my sunroof there was no glass to shatter. It popped my sunroof ABS plastic delete panel on top of our heads effectively doing nothing to us.
It didn’t smash the windshield bc it folded and it didn’t smash the sunroof bc it was plastic. The hood is trashed it’s going to get hung up on my wall at my shop as a do stupid things win stupid prizes trophy.
I’m gonna finish the rest of the season with no hood unless I can get a super cheap one quickly from a salvage yard, but I don’t need an hood to continue test and tune on the street.
I’m definitely not going to put the hood vents back in those got damaged and because my turbos aren’t in the engine bay anymore I’ve been kind of battling lower optimal temps so for my replacement hood I don’t really care what color it is. I’m going to change the wrap on my car so I’m not gonna have hood vents anymore, but I’m gonna keep the hood pins. Yeah I’m not deleting them. I’m pretty sure I’ll never forget them next time. Later today I’ll have some aftermarket lug nuts to use the other wheels with.
Rev 21 immediately had a low load harsh 3-4 shift engagement so I knew kind of right off the bat I was going to want to do a new tune, and I found the edit that caused me to basically hard lock the torque converter at Parth throttle which also is interesting because it’s becoming increasingly easier to decide when I want hard lock because of that edit. I basically had made the pressure floor 130 foot pounds which was triggering hard luck at Parth throttle which is why it felt so harsh it actually cleaned up quite a bit with adaptive learning and just 20 minutes of driving it was already reducing the pressure in the adaptives but I fixed it for Rev22.
So I don’t know if I got lucky and didn’t really smash anything except my hood. And also because I was like a 10 minute drive from my shop or more my son being with me helped hold hood as it sat in the middle of the sunroof opening and we both had a hand on it. I just drove back to the shop like that lol! Luckily, I only passed like four cars so nobody really saw me but oh my God am I so disappointed in myself for forgetting my Hood pins
It could’ve been worse. What if I remembered to put my hood pins in but I got carried away trying to show off for my son and then blew a tire out over 100 mph because I was still on the tires with the exposed steel belts? Also him being with me helped calm me down. I told him Jeez…twice now giving you a ride it went sideways. He said, “It felt a lot faster than last time.” I said, “Shit, you have no clue. We only went about half throttle.”
IMG 3181IMG 3180
802SHO
Man I’m so close to finishing 93!
Quick update. I tuned the car 3X yesterday and I’ve been editing a lot of the hidden shift TCC clutch controls that are extremely powerful scalars. Choosing when hardlock starts and stops, performance and speed lock enables, pedal counts, torque ft.lb thresholds to where I was editing out hardlock moderate throttle and 3-4 drivetrain lash, jolting the front axles.
Big takeaway. Impeller torque by gear works! In fact I set my own intervention with it. And it was an ETC cut. I just found ETC controls to make it a spark cut only so the throttle stays wide open. My torque by gear is more or less a soft boundary I only want enforced with a spark cut (softer cut).
1st gear coupling works!! It was doing exactly as I requested it.
The Tcase low driveshaft torque intervention is history. That sentinel value and turning off advance Trac 100% eliminated it.
The car handles 100x better when the wheels/tires are UNDER the suspension…who would have thought? IMG 3202
And there’s so much more. All the knobs are basically exposed it’s just making them all work together now
bpd1151
Lurking Around
SHOcago 'Burbs
Haven't been here for a while. Holy $.hite about your hood! Geezuz. Glad you & your son, and your beast of a SHO are alright. All things considered.
You're spot on about WTH would've happened with the wheel/tire setup had the hood issues not arisen, and you (fortunately in retrospect) didn't incure more significant damage on a whole 'nother level!
On the positive flip side, glad to see that 93 is going absolutely spectacular! Fun to read. One can sense your enthusiasm jumping through the viewer's screen!
Sent from my SM-S928U using Tapatalk
802SHO
I found what I was looking for. Electronic throttle control (ETC) is now disabled for torque truncation. This is my custom exposed definition. 1.00 is disabled. 0.00 is 100% enabled. IMG 3246
What I did was enable truncation specifically for my torque by gear limits. In my log truncation was only used for 1st and second gear (my only torque by gear limits I made for myself).
So bc truncation was set in VCM Editor for Spark vs Requestor, it was preset to 1.00 for spark and 0.00 for ETC. But ETC vs Requestor was hidden. Now I have throttle cuts eliminated and spark set to 0.80 so spark will be a soft limiter at 20% torque reduction. Think of bowling using the bumpers. I intentionally set up my own bumpers….but they are merely a guide I don’t want a hard cut. I’m using it to attempt to minimize traction loss.
I also exposed LSPI limits and they were hardcoded out set to 3.0 air load. I set them up by temperature. I now have a hard coded load ceiling of 2.0 load if I reach 110 degrees IAT2. If I hit 130+ it’ll drop me to 1.9 load. Thats not a ton of protection for 93 octane but it’s something.
I am seeing <110 IAT2 on my last full pull. I did a 120+ mph pull just min before the full pull with no cool down.
So once the tune has learned and I’ve tested it some I need to do a cool down on purpose. So when I’m using 21-22 psi boost and only 14.5-15.5 spark that heats things up a bit. I don’t have any additional cooling it’s just 93 octane. It would be cooler to run 19 psi boost and 17 spark but overall that’s less power. So I’m getting near max power and keeping knock at bay with 16 spark max and 22 psi. I just need to stay under 100 degrees by the time I hit 130mph.
The car should rip now with the throttle wide open. I changed my low lock to full lock threshold to 420 engine brake torque. And I increased my 1st gear torque to 500 and seconds gear to 550 with the spark cut no throttle cut.
Should be interesting later today and I’m going to test drive it now to make sure low load and moderate throttle stay tamed and drivetrain lash is gone. If so, I’ll then clean the car for the last time this year. Run some errands and later, test it full pull. If it’s off street driving I’ll need to edit a little more
802SHO
Today’s session uncovered another interesting setting that’s now been reversed. With as little as 20 rpm (20 pedal counts actually that’s like a flinch in your foot lol) removed the TCM was permitted to do a change of mind and remain in 1st gear. Other factors present but that was the main thing. I had 3 launches only one somewhat successful and I stayed in the pedal more. Backing off the pedal a hair hoping it would shift actually triggered change of mind logic to stay in 1st. IMG 3263
Hahaha it’s always something. wtf
On the run I actually was able to complete my new LSPI limits held it back bc slot 0 was 110 so anything under 110 would trigger the 2.0 ceiling so I went back and changed it to 115 and 3.0 so anything under 115 would have full air load it wanted but that was my 3rd launch that failed bc I backed off the pedal and triggered change of mind.
So my first attempt (failed) 1-2 shift
Second attempt (pass but LSPI stopped me + some other minor edits to make)
3rd attempt failed. 1-2 shift
I’ve since changed oncoming shift pressures, ramp rate, etc.
Awww so close. This was the best I could do on the second attempt that worked while using traction control which has a 20% ETC reduction IMG 3264
1.9 60’ lol. Guess 300 TW tires aren’t ideal here. But I have a car that makes enough sense to dial in here. 93 octane, no clue what it weighs it’s got 12 gallons here, full cell.
Lost my sunroof delete twice. Retrieved it the first time. Second time…eh…I’ll make a new one. It’s shedding ET and parts lmfao
802SHO
:smash: :typing: Ok HPTuners misrepresented Max Accel. Image
I had this set to 100. Max. Thinking the PCM would be ready for max acceleration. OEM was set to 20 with this description.
Actual description in the A2L which is funny bc the Ford Engineer who wrote it in had a couple spelling errors. IMG 3273
Do you understand what that means? I was giving the PCM an infinite runway, letting excessive wheel spin set its target shift much higher bc it’s essentially a wheel spin filter.
So per Chuck:
The capped-prediction arithmetic checks out. Your 25 MPH/s choice remains a reasonable test.
Using Gemini’s assumed formula at 3,459 RPM:
Acceleration ceilingCalculated predicted RPM
100 MPH/s7,334
20 MPH/s4,234
25 MPH/s4,428
That demonstrates how a lower ceiling could prevent a speed spike from producing an excessive prediction.
I bet Brad left it stock at 20. I’m setting it from 100 to 25 bc with my logged acceleration 25 supports over 1G of acceleration.
My recommendation for Jonny Powers at HP when I send over the full list of custom XDF controls I am using and I edited: ⁠Wheelspin noise filter (dV/dt clamp) for the Anticipated Shift RPM predictor. Caps the maximum vehicle acceleration rate fed into the clutch fill lead-time calculation (1 G = 21.9 mph/s). Do NOT raise above realistic hooked chassis acceleration (20–25 mph/s), or launch wheelspin spikes will cause a massive false Anticipated RPM spike and desynchronize WOT shift timing.⁠
Unbelievable. One common denominator keeps appearing….nothing the ECU does is by accident it’s all in the settings. Unless something is actually mechanically or electrically faulty.
Another one. Stall speed OEM is set to 3,000 rpm. Inferred movement is set to 3,000 rpm for the PCM to consider the vehicle in motion. With those settings stalling the car over 3,000 rpm triggers trans truncation to my throttle while on the brake bc I exceeded both. Both are set to 4,000 rpm now.
Edit: Basically this setting Max Accel 100 only became one of my biggest problems once I found how to launch better. It explains the other WOT Gear shift scheduling overshoots too but it wasn’t until boosted launches it revealed itself as the #1 culprit. Again, nothing is my chance …it’s in the calibration.
802SHO
Moving from Rev23 to Rev24 what’s different?
In Rev 24, the ECU stops fighting its own factory protection routines and starts operating in sync with your aftermarket hardware: your PNH high-stall converter, G25-550 turbos, and XDI fuel system. Instead of hitting hidden software walls that slam the throttle shut, misfire the shift predictor, or peg the high-pressure fuel pump at 100%, the ECU has clean, accurate boundaries for every stage of a street pull.
1. On the Foot-Brake (0.0 mph, 3,500-3,700 RPM Launch): Full Throttle and Boost
What the ECU did in Rev 23:
The moment your PNH converter flashed past the factory 3,000 RPM Stall Speed and Inferred Movement thresholds while stationary, the ECU flagged a stationary stall condition, activated Trans Trunc torque management, and slammed the electronic throttle blade down to 26.5 degrees.
What the ECU does in Rev 24:
With Stall Speed and Inferred Movement set to 4,500 RPM, your 3,691 RPM foot-brake stall sits 809 RPM below the protection trigger. The ECU remains completely out of stationary torque truncation, holding the throttle blade wide open at 82 degrees so the G25-550s build full launch boost and leave the line hard (cutting your simulated 60-foot from 1.94s down to 1.78s).
2. Initial Tire Spin and the 1-2 Upshift (32.0 mph Gate / 5,800 RPM Target): Zero Limiter Clip
With Max Accel. (VSRATE_MAX) set to 100.00 mph/s, as soon as the tires broke loose off the line (95-149 mph/s wheel speed spike), the ECU multiplied that tire spin by the clutch fill time and calculated a phantom 7,334 RPM predicted engine speed while you were only at 3,459 RPM. When the tires hooked, predicted RPM crashed backwards, desynchronizing the shift state machine and letting the 1-2 shift slam into the 7,012 RPM rev limiter.
Clamping Max Accel. to 25.00 mph/s (1.14 G) filters out the wheelspin noise (4,428 RPM max predicted during launch spin) while passing 100% of your real hooked AWD acceleration. As you cross the 32.0 mph gate (synced with a 30.0 mph 2-1 downshift floor so it can never hunt back to 1st), the ECU commands 2nd gear cleanly around 5,480-5,800 RPM, ramps Shift Solenoid C at the faster 125.0 psi/s rate (P07), and completes the shift around 6,450-6,500 RPM without touching the limiter.
3. Roll-Race Stomps and the 2-3 Upshift (59.0 mph Gate / 5,000 RPM W04): Staying in the Powerband
Shifting 2-3 early at 56.0 mph and immediately locking the converter dragged engine speed down to 3,982 RPM, right below the G25-550 boost threshold, creating a massive torque bog entering 3rd gear.
Raising the 2-3 gate to 59.0 mph (6,000 RPM target) lets 2nd gear wind out to approximately 6,280 RPM and drops 3rd gear in at approximately 4,185+ RPM, keeping the turbos spooled.
On the street, syncing the 3-2 downshift with W04 = 5,000 RPM (51.0 mph) means if you stab the gas below 51 mph, the ECU gives you an instant 2nd-gear kickdown with a full half-second of pull before shifting. If you stab the gas at 52+ mph, the ECU holds 3rd gear and lets the torque pull cleanly instead of wasting 0.35s downshifting into 2nd only to immediately upshift back to 3rd.
4. Mid-Range and Top-End Fueling (2,000 to 2,560 psi FRP, 0.80 to 0.78 Lambda, 72 inHg TIP): Sub-90% HPFP Duty and Cooler Cylinders
Asking for 2,386 psi of rail pressure at 5,000 RPM (peak torque/airload) and 2,750-2,800 psi at 6,250+ RPM forced the XDI-60 high-pressure fuel pump to 99%-100% duty cycle, while 74.0 inHg boost pushed 4th-gear IAT2 up to 114.8°F, triggering +0.25 degrees knock retard and pulling timing down to 11.0-13.5 degrees.
Holding desired rail pressure at 2,000-2,100 psi across the 4,500-5,000 RPM torque plateau and ramping to 2,560 psi at 6,500 RPM takes the backpressure off the XDI-60 pump plunger so HPFP Regulator Duty Cycle stays safely between 84% and 88.7%, while the massive XDI 2000cc injectors make up the volume with a tiny +0.20 ms pulse-width increase (5.14-5.95 ms).
Pairing 72.0 inHg top-end boost with staged 0.80 to 0.78 lambda sprays extra liquid fuel directly into the combustion chamber at 5,500-6,500 RPM, cooling the piston crown so the ECU holds its full 15.5-16.0 degrees Borderline spark advance all the way through 3rd and 4th gear.
5. Emergency Street Bailout (C03 = 1, C04 = 250, C06 = 0): Instant Safety Without False Triggers
If you have to feather the throttle 5%-15% at WOT to manage street traction, the ECU ignores the minor pedal movement (C06 = 0) and completes the shift cleanly.
If a hazard (like a deer or traffic) appears and you snap your foot off the gas (greater than 42.7% / 250-count pedal drop), the ECU immediately aborts any pending upshift (C03 = 1, C04 = 250), snaps the throttle shut, and keeps the transmission in the lower gear for maximum engine braking.
I kept this last one enabled and set it to what makes sense to me.
802SHO
The current trim: no hood, no moonroof, 1” spacers, 20x9 Mickey Thompson SC-5 +32 wheels, Pirelli PZero 275/40/ZR20 220 TW.
IMG 3301IMG 3305IMG 3307IMG 3310IMG 3312IMG 3317IMG 3315IMG 3325
I was finally able to dial in the car “enough” so far to an 11.91@118mph with 93 octane on asphalt.
IMG 3341IMG 3346
IMG 3347
This is with less issues than last time lol! This is not fully dialed in. 1.95 60’? I need to drop 200 rpm on the 2-3shift, still need to find what my throttle keeps getting shut in 1st…I raised my impeller limits by gear to 500 in 1st and 600 in second and that helped. My charge air temp cruising was low 80’s around 15-20 over ambient but over 105 degrees by the end of a pull I’ll be in my own LSPI limits. I actually tried 2 tunes tonight. One before this one my LSPI thresholds were too low. I bumped them up a little bit for more headroom and made those impeller edits for this 11.91 run.
Somehow I spaced that I actually bought somewhat ok tires so now it’s time to raise my own impeller limits and see what these tires can take. I’ve got at a modest 2-3 tenths that can be shaved off of that. Plus, is there drag with an open moonroof and no hood?
Things are actually getting somewhere. What even is a good 93 octane pass? I’ve never tried to find 93 performance lol. But my intuition tells me the old setup reduced to just 93 octane would have gotten beat here.
802SHO
What I’m actually pumped about is that this wasn’t a hero pass. Tire pressure I didn’t even check. I thought about changing the oil and filter, bought more Valvoline VR1 10w30 and decided not to change it yet. I’m about 700 miles on the last oil change and on this used trans and PNH Converter. So why change it. I just checked my valve cover catch tanks after this many miles and there was hardly anything in them. I checked the torque on my lug nuts and topped off the fuel cell.
Redemption on taking my son out. We got the trans up to 160 range and did several WOT pulls which I could feel the power fading up top a little. All great to figure out as soon as possible right? So after about an hour I dropped my son off and I checked the data logs we grabbed, my son working the laptop.
Sure as shit my LSPI limits lowered my air actual to 1.85 load exactly how I set it and I was able to see knock retard eventually started adding about 1.5 degrees so 1.85 was too strong. I quickly changed them to this
-110 degrees 3.0 load is permitted
-115 degrees 2.1 load is permitted
-120 degrees 2.05 load is permitted
-130 degrees 1.9 load is permitted
-135 degrees 1.85 load is permitted
-140 degrees 1.75 load is permitted
Raised my impeller torque to 500 in 1st and 600 in second and tuned the car.
I drove out to the good test road and I got the trans like 90% adaptive learning corrected and octane back to -1.00
About 30 min later I’m at the spot but my IAT2 is 82-85 and I’m like…******* I need that to be max 70 to stay out of my temp limits on 93. Well I turned the car off but after like 10 min I figured this wasn’t really going to solve my problem. I then turned the car on and I’m sitting there idling waiting for traffic and my charge temps got to 99. I’m like w t f.
If I start driving it’ll lower it. So I decided to drive down the test road the other way I dont usually go. I got it back down to around 80 after 5 min or so and then I headed back to where I launch. Nobody behind me so I drove up to where I launch. I’ve never done a brake boosted launch this way but my AI assistant said to pump the brake and then press it in hard to trap max brake pressure. Then more firmly stab the throttle and try to release the brake in less than 1 second.
I tried it. I was able to flash the car to over 3,000 rpm but I need to sit on it to actually get 2+ psi. Well it worked pretty good regardless and the flat curve in 1st is literally my impeller limit. IMG 3339
So I’ve come to the conclusion that torque by gear (impeller torque) works great…but on pump gas it’s not needed. I think when I switch to E85 it’ll be advantageous to not blow the tires off and have some sort of limited power on purpose but for 93 it’s kind of in the way.
That’s it. Nothing special. Stop and go 11.91. So many areas that have potential for improvement. I think there’s 2-3 tenths in the tune with a better launch to be made up for on the street. Then put that on a prepped surface and expect another 1-2 tenths. So I do believe it’s a low to mid 11 car on straight pump gas.
It’s going to be a Monster :evilgrin: With sub ambient charge temps with more spark and more boost
Bob from Accounting
Texas
Maybe the heat soak was partially from turning the engine off, then starting it back up? Then driving allowed the coolant to work better? Just throwing that out, you generally don't want to shut down a hot engine until you've cooled it down with a hose, but then again you've got a lot going on in there.
raymo23
