Adaptive learning update.
After Matt mentioned that the adaptive system has finite, calibratable authority, I went digging into the Green Oak definitions to see exactly what kind of correction range Ford actually gave the 6F55.
This ended up being pretty interesting because it puts some real numbers behind the adaptive strategy.
The basic hierarchy I’m working with now is:
Desired phase target
→ base pressure / pressure slope
→ adaptive correction
→ adaptive authority limit
In other words, the target tells the transmission what kind of shift it is trying to produce. The base pressure and pressure slope are the starting hydraulic calibration used to accomplish it. The adaptive system then corrects the result, but only within a finite amount of authority.
That last part is important. Adaptive learning cannot compensate forever for a base calibration that is too far away from the requested shift.
The master clutch adaptive function is enabled in my calibration.
For the normal sequential upshifts, the oncoming starting-pressure adaptive authority is generally -30 to +30 psi. The 2-3, 3-4, 4-5 and 5-6 offgoing starting-pressure paths are configured with approximately -15 to +30 psi of correction range. The 1-2 is configured differently and I’m not assigning the same meaning to its offgoing side because its use/learn configuration is different.
There is also separate adaptive authority for stroke pressure.
The seven native stroke-pressure correction slots contain ranges including:
0 / 0 psi
-9 / +12 psi
-12 / +12 psi
-9 / +8 psi
-5 / +5 psi
-5 / +6 psi
0 / 0 psi
Those are stored adaptive correction limits, not commanded clutch pressures.
I have not yet positively mapped every native slot to a physical clutch, so I’m not going to assign those numbers to individual shifts just because the array happens to contain seven entries.
Boost-time adaptation has substantial authority as well. Depending on the native slot, Ford allows stored corrections ranging roughly from -280 to -500 ms in one direction and +200 to +500 ms in the other.
Again, those are correction limits. They are not the commanded fill time and they are not the amount the transmission has actually learned.
That distinction leads to the limitation I ran into.
I can expose these calibration CHARACTERISTICs in VCM Editor through the XDF work I’ve been doing. That lets me see the configured adaptive limits, selectors and use/learn controls.
What I cannot currently do is simply take the corresponding Green Oak RAM/KAM MEASUREMENT definitions and add them to VCM Scanner.
HP Tuners only allows me to log the channels they expose for this controller. A normal HPT data log also cannot later be opened in VCM Editor to inspect the transmission’s learned KAM corrections.
So at the moment I can see the fence, but I cannot directly see exactly where the adaptive correction is sitting inside the fence.
For example, I know a normal 2-3 oncoming starting-pressure correction can have approximately -30 to +30 psi of configured authority.
What I cannot currently say is:
“The 2-3 has learned +8.4 psi and therefore has 21.6 psi of positive authority remaining.”
That would require direct access to the learned KAM/runtime value, which I currently do not have through VCM Scanner.
There are a few other interesting findings.
The dedicated offgoing slip-pressure adaptive path appears likely unused for the normal sequential upshifts based on its selectors and use/learn configuration. Likewise, the dedicated end-time adaptive path looks likely unused on those same ordinary upshift IDs.
I’m keeping the word “likely” there intentionally. The calibration configuration strongly points that direction, but without runtime visibility I’m not going to turn an inference into a fact.
That also does NOT mean the transmission has no adaptive control over the inertia or overall shift. There are several separate adaptive mechanisms in this strategy, and disabling or not selecting one dedicated path does not disable the entire adaptive system.
The ordinary adjacent upshift Shift IDs have now also been mapped:
1-2 has two configured branches, IDs 0 and 20
2-3 = ID 4
3-4 = ID 8
4-5 = ID 12
5-6 = ID 16
The exact executing 1-2 branch still needs runtime confirmation.
So how do I use any of this if I cannot directly log the learned pressure correction?
For now I have to infer the adaptive behavior from the shift itself.
That actually brings this back to the Torque / Inertia / Overall phase discussion.
Rev11.1 keeps Torque Transfer Time unchanged.
Initial Slip Time, which corresponds to the inertia phase in these definitions, is being shortened 20%.
Overall Slip Time is also being shortened 20%.
That follows Matt’s recommendation to leave the torque-transfer phase alone and shorten inertia and overall proportionally.
Now the data log becomes the diagnostic tool for deciding which part of the base calibration needs attention.
If the torque handoff itself is wrong before the major RPM transition begins, I need to look at controls associated with the torque phase: starting pressure, oncoming/offgoing relationship, fill/stroke behavior and the way torque is being transferred between elements.
If the torque handoff occurs correctly but the engine/turbine RPM continues through the shift or takes too long to synchronize to the next ratio, that points much more directly at the inertia phase. That is where engine torque reduction, oncoming pressure development and pressure slope become especially important.
If those individual portions look reasonable but the complete event still takes too long, then I need to look at how the entire shift is adding up against the Overall Slip Time target.
So instead of saying:
“The 2-3 flared, add pressure.”
The process becomes:
Where in the shift did it miss?
Torque phase?
Inertia phase?
Overall completion?
Then identify which controls actually govern that part of the event and make the smallest correction that addresses that phase.
The other important part is learning over time.
Rev11.1 is going to stay in the car. I’m going to collect repeated shifts over multiple drives and heat cycles without constantly reflashing it.
If the exact same 2-3 or 3-4 progressively changes while the calibration itself remains untouched, that gives me indirect evidence of what the adaptive strategy is accomplishing.
I may not be able to say it learned exactly +6 psi, but I can compare early versus learned behavior:
How much RPM flare occurred?
How long did the inertia phase take?
How quickly did RPM move toward the synchronous speed?
How long did the complete shift take?
How much engine torque reduction occurred?
Did the shift continue improving over repeated events?
That information still lets me identify which phase is struggling.
Then, if another calibration revision is actually necessary, I can make the base pressure or slope change in the part of the shift that the logs show needs help rather than simply increasing pressure everywhere.
That is probably the biggest change in how I’m approaching the 6F55 now.
The adaptive strategy is not something I want to disable or overpower.
The goal is to give it coherent phase targets and a base pressure/slope calibration close enough that adaptation only has to trim normal differences.
If the transmission needs all of its available adaptive authority just to make the shift work, something farther upstream in the calibration is probably wrong.
For the time being the limitation is that I can measure the result much better than I can directly read the learned correction that produced it.
So Rev11.1 becomes an exercise in letting the transmission learn, observing the phase behavior over time, and making the next calibration decision from the phase that is actually missing its target instead of trying to solve every shift problem with more pressure.
0 / 0 psi
-9 / +12 psi
-12 / +12 psi
-9 / +8 psi
-5 / +5 psi
-5 / +6 psi
0 / 0 psi
2-3 = ID 4
3-4 = ID 8
4-5 = ID 12
5-6 = ID 16
Torque phase?
Inertia phase?
Overall completion?
Night and day difference now that the torque converter IS ALIVE
and coupling in 2nd Gear
