6 qt. Oil Capacity
93MTXSHO
Waldorf, MD
I have a bone stock (as far as I know) 93 MTX w/ 195K miles, and ever since I got it, it takes 6 quarts of oil to bring it up to the full line. At 5, after starting it and letting it sit, it still reads exactly 1 quart low. I use a standard oil filter, and I know the engine is CLEAN. I had the valve covers off, and the inside only had a yellow tone that would wipe off easily. I can't figure it out. Maybe someone out here can help me.
olympic
Saskatchewan, Canada
I think I read somewhere that the capacity stated in the owners manual is not correct. So if it takes 6 quarts to fill it up, then that's the correct capacity.
91 SHOplus
Sholess 4 Now
North Jersey
I remember reading another poster here saying that he had an arguement about the oil level in his SHO at a jiffy **** type place. They seemed to think that the yamaha 3.0 and the SLO 3.0 were the same.
Guess they never drove one! :p
Don't forget those jiffy boob places usually advertise "up to 5qts of oil" for their standard oil changes.
jthomas68
Area 51
Mine takes EXACTLY 5 quarts,every time.Fwiw,Doug Lewis at FPS fill them 1/4" above the fill line.
<small>[ September 19, 2002, 03:54 PM: Message edited by: jthomas68 ]</small>
MeShoHorny
@dm1n15tr@t0r
NY
If you are using the larger F1 Motorcraft oil filter you will indeed need 6qts.
MilTownSHO
Horicon, WI
jthomas68:
Why does he fill it 1/4 over? Mines a little over and I was gonna drain some but **** if hes does it, it cant be bad
pete c
ellington, ct
6 qts puts me just past the full mark with the FL-1A filter. I believe the larger filter adds a bit more than a half qt to the capacity. So, with the itty bitty 400 filter a little more than 5 qts should do it.
