I will start by saying that for the last 10 days I’ve searched the forum and online resources for countless hours. I just can’t figure it out.
2011. I bought the car running and driving, but not well. I did colder plugs gapped to .27, coil packs, oil change, PTU fluid, electronic boost control solenoid(Pierburg 3 port version where the electrical connector faces the passenger side while standing in the front of the vehicle).
*The car has a 93 octane GH tune. I did install a Motorcraft 3 bar map sensor. The car runs beautifully, but will only make 5-7 lbs of boost on live data.
*The car has 93 octane fuel with the learned octane adjustment sitting at 0
*I went through the shifting cycles and idle cycles after tuning it.
*My fuel trims are with +\- 3%
*There is a check engine light on for evap purge valve.
Is it possible the hoses to the boost solenoid are routed incorrectly?
I tested the electrical connector to the solenoid and one pin has 12.6v with the key on and the other has 3.53v, I was thinking this could be an issue as well.
I’ve checked my diverter valves and they don’t seem to have any excessive movement or tears. I don’t hear any “blow off”
I had a stock 2013 SHO that was day and night faster than this GH tuned 2011. I absolutely believe it’s something mechanical and not their tune.
Any help would be appreciated. Thank you
