4 sec. rev down?
mlatten
Mons-taurus
Suffolk, NY
Under no load, my 3.0 takes 4 FULL seconds to go from 4k rpm to idle. This just seems really long, and I have a hard time banging out quick shifts because of this delay. I takes forever between all shifts, really. This only started about 6 months ago, as it used to drop straight to idle from any RPM - great for fast shifting.
I've cleaned my IAB fiercly and have no codes to share?
Is this normal, or should I investigate further (gas milage is pretty much the same as always).
Thanks for any input.
Matt
mlatten
Mons-taurus
Suffolk, NY
Just changed it w/ a new one about fifteen minutes ago (Motorcraft).
Same bananas. But she runs, and that's all I can ask for.
Thanks guys,
Matt
SHO#7
Cincinnati
What did you clean your Idle Air Control motor with.
Carb cleaner will melt the insides.
Mike
Racer X
SHO Pilot, Retired
Connecticut
Mike
Oh noes!!! :eek: Tell me you're not serious! :frown:
mlatten
Mons-taurus
Suffolk, NY
I just used a lot of electronics cleaner on each part that I broke down along with an old toothbrush.
Thanks for the advice. I disconnected the battery for about an hour and when I fired her up I did followed the instructions to reset the idle. Still does it.
I look at it this way: even though I have no codes . . . at least I don't have any codes. lol
Thanks again.
Matt
Shoaz
Studly dood
Scottsdale, AZ
You might also check for vacuum leaks, in this case, a very small one.
The Pumpkin has a weird problem with intermittent high idle, and it's usually the vacuum plug that I put over the EGR port (since the EGR hardware is gone). For some reason the car eats those plugs and they disintegrate and leak after only a short while...but I don't think that's the entire problem so I'm interested in what you find as well. I'm already thinking I need to go through the IAC and the TPS.
mlatten
Mons-taurus
Suffolk, NY
Hate to be a part swapper but I had a few hours between classes and tried some things. Changed and retried the vehicle after each part, no changes noticible. Coil pack, DIS, BCM (the black relay box mounted to front of engine bay w/ 4 screws, right?), swapped on another intake w/ its own IAC. Car makes all the same sounds and revs the same.
I cleaned the MAF w/ electronics cleaner (let it soak on). Since it's an MTX, could these be symptoms of a failing MAP sensor? Would that throw a code?
And unfortunately, no signs of a vacuum leak, and I've checked and sanded most grounding points.
Thanks again,
Matt
jelloslug
Digital
Greenville, SC
Does it seem low on power? A clogged cat or another restriction in the exhaust could make it rev down slower.
somedude_001
Western NY
well that explains why mine is throwing a code now :(
here is a super quick way to tell if its the IAC. start the car let teh idle settle down to normal (800~) then unplug it while the car is running. now drive the car and see if its any different.
i'm in buffalo NY I have a known good IAC if you want to try swapping it out be my guest. i'm not offering to give it to you but your welcome to try it.
mlatten
Mons-taurus
Suffolk, NY
Well the cats don't glow after driving, or rattle when smacked - so I'm taking them to be OK.
As far as power, well, long story, but it turned out last week that my timing belt was set one tooth off on the crank (ATX timing on an MTX) for the last year. I had plenty of top end, but no torque. Thanks to these archives though I remedied that, and she's better in that respect, but still had the long rev down. I thought the CPS was bad too, but it turned out the pulley and gear had walked out about a quarter inch due to a loose bolt - really loose :nut:
I'll pull the y-pipe anyway and use a shop vac to investigate tomorrow.
Have we ruled out the MAP sensor?
Thanks as always,
Matt
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Something else that has yet to be mentioned....
VSS
I chased my tail trying to fix the same problem, only to find the speed sensor was the culprit. :thumb:
mlatten
Mons-taurus
Suffolk, NY
Would a VSS throw a code / would it slowly go bad or is it totally gone once it's done? At least it's an easy fix!
Matt
gmorrell
Never been a noob...
Colorado Springs, CO
VSS drives some return to idle strategies when the vehicle is moving. Quick VSS diagnoses: Does the cruise control function?
There are some IVSC quick tests as part of KOEO, but they don't test the VSS, and I don't recall any VSS-related codes, so I don't think it can throw a CEL if it's ****-up. (IVSC = Integrated Vehicle Speed Control; means that cruise functions are integrated into the EEC, instead of a separate control module.)
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
When my VSS was going bad, the cruise did still function, but it "trailer-braked" a bit.
No code was ever thrown.
All I had was that annoying haning idle when coming to a stop sign or red light.
mlatten
Mons-taurus
Suffolk, NY
Cruise works, and I don't have any wierd braking issues. It's an easy fix for the MTX; maybe I'll go grab one.
Thanks again,
Matt
