#4 Fuse Blown? HELP!!!!!
National #19
Dubuque, Iowa
My #4 fuse is blown and everything that goes along to that does not work. I need help, any reasons why or how it blew? and what are some possiable reasons?
Thanks,
Andy
Jrodm12
Wa State
well what else isn't working what exatcly stoped working what where you doing when the fuse blew where the lights on need a lil more info...
National #19
Dubuque, Iowa
Well i had the lights on and then it blew while i was driving, i got a 30 amp fuse in there now and it hasn't blow, but my gauge cluster and eatc doesn't light up either.....
TYSHO
Earth
Take that fuse out! When a fuse is blown it doesn't mean it needs a higher amp fuse. You're looking for trouble that way, if not already!
Turn your dimmer switch "on" and see if the gauge cluster lights up while you have your parking/head lights on. If so, it's the switch. Also, the chime box is ran off that circuit, so you can unplug that and see if that's the problem, if it's not the dimmer.
