3.2 l or 3.0l
Tokuman
Virginia
I realize this is a stupid question but how do I tell if I have a 3.0 or 3.2?
In the car or out? 3.2 cars are automatic trans & 3.0 came with manual. Unless someone swapped the engine before you got it.
jimtash
nc
Look at the coil pack. 3.0 sits flat. 3.2 sits slightly sloped.
Irish Pride
Irish Inside
MusicCityUSA
3.2 will have a DPFE mounted on the back side of the intake. 3.2 uses a single belt accessory drive system, 3.0 uses 2 belts. 3.2 has coolant overflow bottle mounted inside the fender behind the battery, 3.0 has coolant bottle mounted next to radiator.
All this info is moot if a swap has been done though.
Tokuman
Virginia
Thanks for the help! I don't understand why someone would want to swap a 3.0 instead of 3.2 unless it was out of convenience. I'm betting mine is 3.2 because I bought it from the original owner and he didn't mention anything about that.
DJSHO91
Durham, NC
If it is a 1993-95 and has an automatic, it is a 3.2, end of story. If it's a 5spd manual, it came stock with a 3.0L V6. Some folks, in modifying their 5spd models, have added the 3.2 block for a little more grunt. If this is done, the original owner would have most likely have pointed this out as a selling point. :salute:
myculito
