THank you Fred,
As the kids say...You Rock!.
I'm just about final decided that I'm going to rent a tow bar and tow it a mile to my shop and have them determine what is really wrong, since the info from the 95 seller kid doesn't line up with what he thinks is wrong. Again he replaced the cps and the timing belt and then gets no fire to the plugs...Then says that he thinks compression is low on one cylinder because the engine isn't turning fast enough..cranking....but didn't do any compression testing.. Originally he said he thought there was a broken piston rod, but I cranked it over and I think I'd likely hear something that didn't sound right if that were the case and it doesn't, it just cranks over and doesn't fire. I haven't taken the time yet to dig in and see if there is, or if it is a fuel issue or what, But he never dropped the oil pan to see what's up, he didn't pull any plugs to check compression, I don't see coolant in the oil or oil in the coolant, and he said it was running fine and then quit. He and a friend decided it was the cps. I'm gonna ask him next why he decided that was the problem, and it may in fact have been, but if it was, replacing it correctly and the timing belt correctly shoulda solved the problem if that was the right diagnosis, I'm thinking he was wrong about what happened. Could have been the ccrm or 20 other things, and he isn't a mechanic, but has a friend who he says knows SHO, but if that's true hows come he didn't get it running... THnkas again for all your help and experience,
T
