3.0 heads 3.2 block with turbo
davekar
Pa
i know people run turbo systems on 3.0 engines and 3.2 engines but i was wondering when you do the 3.0 heads on the 3.2 block if that gives you a higher compression ratio that wouldnt be good for turbo set ups?
Twisted6
Charlotte, NC
By itself, no, does pose a tuning problem though. With higher compression, your margin for error in tuning is quite small.
biker889
Quakertown PA
No, The only diff. between the heads is a few mounting holes and a mounting boss. The intake cams are the only main variation between the 3.0-3.2 headwise.
somedude_001
Western NY
+1. unless there is something wrong with the heads on your 3.2 just swap the intake cams from the 3.0.
Satchmoz
