255lph fuel pump?
Mr Anonymous
Tire Wall
Walbro GSS342, and you'll need an adjustable FPR. I used the Aeromotive 13102 on the stock fuel rail, but I'm guessing you'll need to plumb in a different model.
E1 v2
crash tested
holiday inn
I used a TRE Performance 255 LPH hi pressure fuel pump with the stock FPR. Worked fine on my M90 supercharger setup, still works fine with the temporary stock drivetrain in the car too.
Siman
Location Location
Aromotive makes a drop in 340 lph fuel pump we use 2 of them in the evo and it should drop into the SHO. I have one sitting on the bench at home waiting for its new home in mine. Just need the pressure regulator.
Siman
Location Location
Yeah i was considering it, but i want to run 2 custom fuel rails for both sides of my engine. I was thinking of a -8 an system from the tank forward y adapter to both fuel rails, then a y at the other end to the regulator, and -6 an back to the tank.
