2015 Non PP Brake suggestions?
321GO
What brake upgrade / brands suggestions do you recommend?
thanks.
321GO
Rotors, Pads, calipers. Just something that works better than the stock ones, Looks cool and has good durability.
Depending on how much you want to spend you can get:
a power stop kit or simply the Top Cop pads
ebc blank rotors + ebc yellowstuff pads; upgrade to slotted rotors if you like that look
or simply, the rotors and pads for the Perf Pkg SHO
Calipers ... IF the PP calipers are still different than non-PP, that would be a worthwhile investment. IDK if someone refurbishes PP calipers/paints them readymade for purchase. You could choose to paint the calipers pre-installation, or simply get MGP type covers.
Lostneye
NY
TCE has Wilwood kits if that's in your budget. I don't know what your expectations are but the OEM PP stuff is fine for me.
Lostneye
NY
Since the rotors and calipers show to be the same, I'm thinking about putting the OE PP pads on mine...
The OEM PP calipers should have cross drilled pistons and high temp seals/boots, otherwise they are physically identical. PP pads are a different shape as well as a different pad material but are interchangeable.
myculito
