2012 SHO rear turbo caused engine starvation
Mattpitts25
Point Marion Pennsylvania
I’m new to the forum. I am looking for advice or someone willing to help me get my amazing super awesome SHO back on the road. So, I used this car as a daily to get to work in the coal mines here in PA well, I ended up getting smoke out of the tail pipe but it turned out to be blow by(really bad blow by) didn’t know much about turbos just that they make the engine vroom with boost and they look cool I don’t even know that they was powered by the exhaust! lol well I knew bare minimum let’s put it that way. Like a cave man that can decipher what it looks like does and that it’s needed. But I can’t seem to find an engine that is in my price range. Hoping a SHO enthusiast like me would be willing to see it back on the road rather than tore apart and put in a scrap yard somewhere. Needless to say I need HELP. Lost my job and a lot more than that too. So, can anyone tell me what I should look for as far as things I should do when I am able to get the engine as well as what I should check on the new engine before install. Or, would be awesome if this comes true but maybe someone out their has an engine that is taking up space and is willing to let it go cheap or free I’ll pay shipping cost and all. I really want my SHO back since owning my SHO I fell in love with it like it’s in my top 5 favorite cars right next to the Lamborghini huracan and the Lamborghini Aventador SVJ like legit will be one of the cars I keep in my garage for the rest of my life. lol when I put the new turbo cartridge in the engine decided to starve itself and is now locked up. So please help me somebody.
SnuffyTheSeal
Florida
There's a couple of things you can do before you go the engine replacement route unless you're absolutely sure that's what it needs. These engines get some pretty bad carbon build up and that can potentially cause blow by if the engine isn't sealing properly. Unless somebody has checked the walls of the block with a scope for scoring you may not need an engine right out of the gate. Teardown and piston ring replacement or media blasting is still expensive but less than a motor. Also, check your PCV valve. If the valve is stuck open it can cause a lot of smoke to come from the exhaust. It's a $20 part and worth throwing at the problem before you go for the big bucks.
Mattpitts25
I did the pcv valve already and put a new turbo on it I was thinking oil caused it to hydrolock but I havnt checked it yet
raymo23
