Winter is coming and with the first snow we've had I've noticed that the rear defrost is not melting the ice formed on the outside of the rear glass. Also, I do not see the warm lines clearing the fog on the inside.
Switch light turns on and it times out as it should.
I checked fuse 20 for continuity with a tester and it passed and swapped relay 56 with 55 (windshield wipers) and wipers worked after the swap.
I also found that cabin fuse 43 affects the defrost but also other stuff that is all working so this should not be the culprit.
Haven't checked the continuity on the glass element, not sure where the wires are but meanwhile, any suggestions?
