tardboy21
I opened up the transmission Saturday and checked the resistance on all the solenoids and they were all within spec. The veins and the pump body looked good. Put it all back together, flushed out the old fluid put in mercon v and a new filter and I am still having issues.
seems like 45-50 steady driving the RPMs move up and down a little, almost feels like a downshift/upshift.
and steady driving at 65-75 it does about the same thing.
1-2 is still HARD
did you have the A/C on while doing this? I've found sometimes mine shifts a little hard when the A/C is on. It won't slam gears, but not quite as smooth as when it is off. It will also cause the RPM's to go up a little while cruising every now and then.
