jmpSHO
I am selling my 94 Taurus SHO 3.2 Auto. It is red with grey half cloth and half leather interior. The body has some cosmetic damage on the front bumper cover (I will include a front bumper cover that has been sanded and primed just needs to be painted and installed) and a few dings here and there, nothing major and ABSOLUTLY NO RUST. I love this car and I drive it everyday but I already have another 95 SHO that I have had for 7 years and I have no use for this anymore. It has 131k and it runs and drives perfectly. I have owned this car for about a year, I am a mechanic and I went through this car pretty good and have done alot of work to it. I will try to list everything but I may miss a few things and I have receipts for everything that was done. New A/C compressor (Ice cold A/C), has the upgraded hardbutton EATC, new radiator and complete coolant flush, just flushed the PS fluid with Mercon V, new red slicone intake hoses, new intake gaskets, new IAC, new front Brembo rotors with Ford superduty pads, one front caliper is new, new valve cover gaskets, plug well seals, platinum spark plugs, A/C Delco wires, new cam sensor, new VSS, new upper and lower speedo cable, new alternator with underdrive alternator pulley, new KYB front struts with Eibach springs (car will come with rear Eibachs, not installed yet), new front strut mounts and bearing plates, new passenger side front wheel bearing, new inner and outer tie rod ends (both sides). I replaced the airfilter last year when I bought it as well as the fuel filter, both have roughly 10k on them. I have used nothing but Mobil 1 oil and oil fliter in it since I have owned it. The only issue with the car is it has a harsh 1-2 shift and it only does it once and a while. I just recently changed the transmission filter and gasket and did a complete transmission flush with Mercon V. Just last week I replaced the subframe bushings with Gen 3 bushings on all corners, new front and rear swaybar bushings and front and rear stabilizer links (both sides). Also just had a four wheel alignment last week and new front strut rod bushings with the strut rod cups welded. Just a few days ago I replaced both rear rotors, pads, both rear calipers and brake hoses.
Interior is in ok condition, no major rips at all and it has a Sony AM/FM/CD player. Call 781 408 1560 with any questions, I will post pics tomorrow. Might be interested in a trade of some sort, let me know what you have. Also, I have no problem delivering this car, I will even go as far as 4 or 5 hours from Mass. I would drive this car anywhere, my girlfriend drove it to Florida twice and I drove it to PA, NY and NJ a few times. It is for sale locally but I would prefer it go to a forum member.
Just want to add that it will also come with four new tires (Bridgestone Insignia) on slicers that were sandblasted and painted dark charcoal, 2 wheels have been painted already the other two were sandblasted only, if I have time I will do the other two as well. They are not on the car now but I will take pics tomorrow.
