pitaSHO
Why do I do this to myself?
If you're looking for a very nice looking black/black 93 MTX, this is it. This is almost the stripper version; no moon roof, no keyless entry, no power passenger seat. It does have full leather, which is probably a 9/10. I have had this car for two and a half years now and have been very happy with it. The only reason I’m selling it is because I commute 90 miles a day and am looking to get into a Honda to save on gas. This car is in very good condition, both cosmetically and mechanically.
Pro's
Good paint - no rust (less than the usual wear and tear for a car of this mileage)
Great interior - no rips, tears, or smells (driver's seat is not ripped)
Good tires - almost new tires on almost mint slicers
Steering wheel is not torn or worn out - in great shape
AC blows COLD
Rear defroster works
Clutch is in good shape
Alpine CD player
Good cylinder compression
Maintenance
Fully 60k'd
*water pump
*crank sensor
*timing belt
*Ford front crank seal
*Rod bearings
*Autolite platinum plugs
*Valve cover gaskets
*Cam seals
*Shim adjustment
*T-stat
*Upper and lower radiator hoses
*Oil pressure sender
*Coolant temp sender
*New battery
*New belts
Valve stem seals
Outer tie rod ends
Inner tie rods
Coolant overflow bottle
Radiator - used, but no leaks
Windshield wiper motor
Alignment
New headlights
Mods
12” Cobra brake kit
94/95 front spindles
SHOSource front and rear reinforced motor mounts
SHOSource stainless steel catback exhaust with Magnaflow mufflers and tips
SHOSource stainless steel catless equal length Y-pipe
Full length subframe connectors
Aluminum subframe bushings
Stainless steel brake lines all the way around
Super Blue brake fluid
Tokico struts
Eibach springs
All strut mounting hardware replaced
26mm rear sway bar
TPR bushings front and rear
Both front lower control arms
Hard-button EATC
K&N air filter
Cons
*220k miles
*It needs a rear main seal at some point. I’ve replaced every other gasket on the block except this one. It seems to go through a quart of oil every 1k miles or so. Replace when it needs a new clutch. It also may need an oil-cooler-to-block gasket. It leaks a little where the oil cooler, to which the oil filter attaches, is attached to the block.
If you have any questions, please let me know. The car is currently my daily driver, and I drive 90 miles a day to and from work, so the mileage will go up until it sells.
Asking price is $2300 - BLACK PRO RACE II WHEELS NOT INCLUDED; WILL COME WITH STOCK WHEELS
Thanks for looking.
Chris K.
three six zero nine nine one four seven four nine
Pro's
AC blows COLD
Alpine CD player
Maintenance
Fully 60k'd
*water pump
*crank sensor
*timing belt
*Rod bearings
*Cam seals
*Shim adjustment
*T-stat
*New battery
*New belts
Valve stem seals
Outer tie rod ends
Inner tie rods
Alignment
New headlights
Mods
12” Cobra brake kit
Tokico struts
Eibach springs
26mm rear sway bar
Hard-button EATC
K&N air filter
Cons
*220k miles
Thanks for looking.
Chris K.
