1992 SHO problems need help asap
Timking01
missouri
Alright well the car is still spiting and sputtering i put a new mass air flow sensor on it and plugs wires and a coil and that seamed to fix the idiling problem i was told it could be the fuel pump but when i turn the key on i can hear it kick on perfectly fine so anything would help need it running asap thaks
sperold
Last to Know
Get a code reader or learn how to pull them the other way (search this forum) and see what the car is telling you.
You can take the pressure reading on the fuel rail past the regulator and that will tell you if there are problems with that system.
How much of the top and front 60K has been done from the information you have?
The new timing belt and crank sensor is always money well spent.
I assume you have done the plugs and there was not oil on the outside of them?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
More info...when does it spit and sputter...on the gas or idling? Does it run when on giving it gas? Any CEL light? Any time it sputters and then doesnt (aka only when cold)?
The more info you give, the more likely to get a better answer to your problem.
Timking01
missouri
it does it when driving and i was told that it could be my ignition control module so i was thinkin of pickin up one of those tomorrow because now it wont even start and the other day i was on my way to work and it just died out of no where and yesterday i was running some test on it since it will not start and i am not even getting spark
