There are write ups here on the forum and a very good guide in the SHOPhoenix page.
I'm getting older and don't have a lift. Doing a clutch is a weekend job for me now. Without any snags coming up, my goal for day one is to get the trans out, clutch swapped, trans back in, and subframe back up. At that point I can remove the engine support and close the hood for the night if it's getting late. Usually the next day or the following weekend I'll button up everything else and take it for a drive. It can be done in one day if everything goes smoothly and can be done in an afternoon if you have help.
My best advice for this job is to take an old subframe bolt and grind off the head of it. Use this as an alignment pin for reinstalling the trans. Makes the job 100% times easier if you are doing the job by yourself. I use the far right hole in the engine and once the trans is on the bolt/pin you can easily get it lined up and on the dowels.
-Chad
