1992 SHO bad idle
shojoe1997
new york
If i have the heat, defogger, A/C... anything having to do with air my 92 SHO will not idle. It will go up and down quickly and even stall if you dont tap the gas. Once in a while the engine light comes on. Does anyone know what this could be and have had the same issue?
sounds like you have a serious vacuum leak in the hvac controls somewhere. unfortunately, that means you get to tear the dash apart...
actually, if you pull the eatc unit out, and trace the vacuum lines, hopefully you will find where the leak is.
NoSlo
SHO Owner
Portland, OR
If you find the vacuum hose in the engine compartment that supplies the climate control system, you could pinch it off with a clamp once you set the EATC to the position you want. This should solve the idle problem if it is a post-EATC vacuum leak. I was thinking the vacuum reservoir on the back of the intake, but I think that is vacuum just for the butterflies.
A vacuum leak might not be the only thing possible; the AC Compressor is turned on in most climate control modes and could be dragging the engine down; you can discount this possibility by disconnecting the pressure switch connector on top of the AC canister, or disconnect the connector on the AC clutch.
You could also try an idle relearn - disconnect the battery for five minutes with the light switch on. When you reconnect, start the car and don't touch the gas pedal. Let it idle for several minutes, while you turn on all the accessories and play with the EATC in all modes. Then finally go for a drive. This might re-learn idle and force the engine management computer to deal with keeping the car running even with whatever the problem is.
if the description was accurate, it is not the a/c compressor - he said in any position except off he has the problem, but the a/c compressor will not attempt to turn on in the 'floor' position for example.
resetting the idle is not a helpful exercise at this point, if the description is accurate that the problem only occurs when the climate control system is turned on. The point of having a description of the symptoms is to narrow down the possibilities, so we should not just throw out everything that comes to mind, rather only those things that are related to the symptoms described.
myculito
