2011TAURUSSEL
2014 SHO LMS Stage 1 V10
During my last alignment in September along with state safety inspection NTB tech noticed leaking on rear strut. He showed the area and I held of repair figuring I could either do myself or still have done cheaper.
Fast forward to now moved to house getting settled and finally getting around to project. Shocks ordered as set SENSEN which is one of the OEM vendors for my 2008 Volvo XC90. Based on previous good luck my preference was Bilstein bit couldn't find for Taurus. SENSEN shocks are on property awaiting change most likely tomorrow.
My question is.....Are they that simple to remove and replace? From what I can see two bolts one upper and one lower. If they are as easy as my 03 Durango I didn't even have to remove tires for that one.
I changed shocks and struts on the Volvo and although the shocks went through the strut it wasn't that simple. Should have been but driver side lower housing did not want to part with old shock. Took a while and a few words that would make even the saltiest sailor blush but I got it.
I am at almost 32K and I know a bit early but leaking is leaking. My guess is the OEM Motorcraft junk shocks is exactly that.
Has anyone had occasion to R/R the rear shocks on 2014 models? Specifically 2014 but any 2010-17 SHO models my guess is other than the brake upgrade for 2013 the rear suspension at least shocks should be the same.
