Starting Issues
goalieman59
Learning Slowly
OFallon, IL
The car does not like to start the first time you crank it, if you hold the key it will start after a few, or if you stop then try again it starts right up. Any ideas on what it is. I just replaced the starter and battery in the car, has had a fuel pump with in the last 6 months. And a new fuel pressure regulator last summer.
frosho
WOLFMAN
Tyngsboro, MA
Do the EEC self-test and see if the computer has any codes stored.
Sounds like a cam sensor.
goalieman59
Learning Slowly
OFallon, IL
I will pull the codes this weekend, i know I have a code 332, but that is a ongoing issue.
