Intake ports
StillDyl
Oregon
does anyone happen to know that weight of the intake manifold...
or have one lying around that they will weigh for me. or have a guess.
mines like 35lbs.
thank you
StillDyl
Oregon
its for a gen2 fyi
and i dont want the weight of the crossover tubes. just the ports
krednjen
Kit car/90 SHO Derek SA TX
San Antonio TX
I got 36. No throttle, IAC, DIS, EGR. Just runners, couplers, and plenums......non ported.:) OOPS.......with crossover.
StillDyl
Oregon
k thanks.
if its off do you think you could see how much it is with out the cross over... thanks alot though
StillDyl
Oregon
shipping them to get them ported and my buddy (jonmon on here) his dad owns a UPS store so we need the weight to get an about price
Vnuk1
Mr. Mayhem
Engine Weight Lbs.
Block, crank & pistons 160.0
Oil pan 8.5
Chain cover 6.5
Water pump, pipes & hoses 9.0
Rear ex. manifold 11.0
Rear head 29.5
Front ex. manifold 11.0
Front head 29.5
LIM, injectors and fuel rail 11.5
Rear valve cover 5.5
Front valve cover 5.5
Surge tank and attached runners 16.5
Intake 90, throttle body, IAC, TPS 5.5
LIM runners 5.5
UDP crank 4.5
Belt tensioner, idler pulleys, PS pulley 5.5
Alternator bracket 8.0
PS pump 3.5
Front, rear motor mounts and tranny mount and bracket 25.5
Oil cooler, oil pump pickup, crank windage tray, oil separator 6.0
Oil pump, sprocket,bolts and exciter ring 3.0
Rear cams caps & buckets 12.5
Front cams caps & buckets 13.0
Bolts, timing chains, tensioners and misc 15.0
Head bolts 4.5
HotRodKid
mmmmm ... turbo
Western NY
consider the weight of the crossover to be the weight of your box / packing
but it doesnt really matter, because this wont be an oversize package, nore will it be near the weight limit, so nitpicking the weight isnt really gonna make a difference in price for ya
