no headlights
roushi
Manitoba
ok so i was driving down the highway and my lights went out, now the lights will not come on. I have no low beams, and no high beams what so ever.. The only thing that comes on are the daytime driving lights..
I have check the fuses, and they are good. Anyone know what the cause might be? relay maybe? my highbeams have never worked since i got the car
please help
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
What year is your car?
I'm guessing that your multi-function switch has failed.
it seems like the most common problem with these, in the case of malfunctioning headlights
Storm-Chaser
Shit Louis
That was my initial guess - the multifunction switch.
When I picked-up my current SHO in Massachusetts, as I was pulling out of SHOBam's driveway (now Bruce M), the lights failed. After a few "vigorous" cyclings through the left-right turn signals, the lights came back on.
The SHO had been sitting for months, and I suspect that corrosion due to lack of use caused the problem. More than 15 months later, the lights still work and the only other problem I have had, has been the right turn signal not working correctly (it rapid-cycles) only when the high beams are on.
Guess it's time to disassemble and clean the MFS.
Disclaimer: I did not buy the SHO from SHO BAM, he graciously offered garage space where I changed two broken front springs before driving the SHO home . . . .
Thanks again Bruce ! ! ! !
:wave:
roushi
Manitoba
Ok, so I am guessing that the only place to find one would be a wrecker? thanks for your input on this.
AREA 91
Area 91
You can get them new, but I believe its more costly
Strait from rock auto:
1994 FORD TAURUS SHO 3.2L 195cid V6 MFI (P) : Electrical-Switch & Relay : Multi-Function Switch
Item Price Core Total
ACDELCO Part # F6247 {#88923951}
Headlamp Switch & HDLP DIMR & PARK & T/SIG & WSW & WSWA COMBINATION HEADLIGHT DIMR, TURN SIGNAL AND WPR SW
$42.79 $0.00 $42.79
:p
roushi
Manitoba
they want $110 CND for a new one, and $90 for a used one here, i think im getting screwed lol
