Clutch Replacement Procedure (long)
Bizzy
another question, if using the engine support brace, you do not need to jack up the engine vial oil pan do you???
and I'm going to try to keep from removing the shifter completely from the car
Andrew
Andrew, the answer to your question is technically no. You shouldn't have to put a jack under the oil pan if the engine is properly supported from above. HOWEVER, I would. I just don't trust anything, especially when a 400 pound motor is swinging over my noggin. You could use a bottle jack with a block of 2x4 between it and the oil pan and that would take up minimal space and would not likely get in the way.
dohcsable
Gold Calipers>*
Indiana
awesome, I kinda worried about the eyehooks I used only being rated to 400lbs.....lol
but I'm also doing rod bearings as well, so it'll all have to come apart anyway.....lol
Andrew
ras2433
Forced Inducted
Wap Wap
Sorry didn't mean to **** you off!
Goes to show you not everyone knows what you know...
once again i apologize.
Bizzy
I'm not ****** off, just taken aback by the accusation of plagiarism. Especially since credit was given at the top of the write-up on SPP as well as it being mentioned here when I added it to SPP just 2 posts above your own. No worries though.
NCSHO95
nc
Hey I need a part number for the carrier seal ASAP!
Need to order parts today if you can help with PN!
Ordered throwout bearing, rear main seal, oil pan seals, and bought a OG
Clutch kit from fellow forum member
pls get back to me part number today:munch:
AREA 91
Area 91
FEL-PRO Part # BS40623 {Rear Main Seal Set}
Dual Overhead Camshaft Engine; Rear Main Seal Set; Rubber; One-piece
$21.79 $0.00 $21.79
