are these the original plug wires
Phoenix
SHOHOLIC
QC , Canada
It looks like it , the color is good plus they have this plastic wrapped around. Theres a slight chance they may have been changed with motorcraft replacements though. I think the originals have numbers on them 1 to 6 for each cylinders.
itwonder
VA
Unless the wires are arcing, stiff, or have resistance greater than 5K ohms, it is a waste of money to replace them. You will see zero performance difference. My original wires were on for 180K and 15 years. There was really nothing wrong with them when I replaced them; still have them for spares.
shoon
cliTaurus
Dawson Creek, BC
X2
Stock replacement wires are numbered as well, I got a set of motorcraft replacement wires and they are numbered.
Brett
SHOs before HOs
Minnesnowta
I never tested ohm of my old plug wires. But on an uphill freeway ramp i made it to 40mph from 5-10mph with the pedal to the floor. Plug wires on that car (224k silver ATX pictured in sig) were night and day. Most SHOs are high mileage now and as a result most will feel a difference from some new wires. I have on all four SHOs ive done it to. one being a 113k motor. Anything over a 100k is too long IMO. If your thinking you need new wires, i'd imagine it isn't for no reason, car feeling sluggish? Go through the usual and cheaper culprits, new plugs, run the codes, then come back to wires.
Storm-Chaser
Shit Louis
The Motorcraft replacement wires use to have the date as well. I don't know if they still do, but I think I've seen as recent a date as 2004 on one set of Motorcraft replacements.
:burnout:
chevrolet
sommers in N.C.
The rear plug banks will be compromised by h2o if the hood seal is not fully intact. It won't matter how good the wires are.
