Rear Wheels
cobrakidd03
michigan
I just noticed the the rear wheels on my SHO are tilted inward on both sides. What causes this? The driver side is the worst. I also noticed that the in side of the tires are really worn.
Kens1992mtxSHO
The Commonwealth
Depending on the year of you SHO (89-92) you'll only be able to adjust the toe on the rear.
Things that can increase your rear wheel camber:
Worn Strut mounts(not visible without taking the suspension apart).
Worn Wheel bearings.
Worn Suspension bushings (control arm bushings...both inboard and outboard).
Tweaked rear strut towers (you would have to hit one helluva dip in the road....reapeatedly...).
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
how old is your suspension? I would bet its the mounts more than anything. mine did that until I got new mounts.. :) It did turn really good tho when it was "wrong" lol
cobrakidd03
michigan
I just bought the car last friday. I am pretty sure it may be the original suspension. it seems to be tight as far as going over dips. the car doesnt bounce up and down after going over dips.
encryptshun
Florida
my car bounces like a boat when going over big dips, would could that be? (sorry for thread stealing)
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
One good thing is, that when it gets old, your pretty much forced to update things. You can get the eccentric bushings for the ends of your stamped LCA's, but for about the same price, you can get those sexy tubular control arms. You can't really get the strut rod bushings without the LCA's out of the way, so its a good time to do those too. :)
It's a pain, but if you have a friend with a torch, you'll have a lot more of an enjoyable time swapping them. :) To change the mount up top, you almost need to remove the whole thing so while your in there.. might as well ya know? Good luck..
SeanMc
NoMoSHO
I have Koni/Intrax and rear adjustable arms...they still point out a bit. But I have it set to 1.2* of negative camber :biggrin:
yamahaSHO
E85 whore
Arkansas
My '95 had only one cambered bushing per side. I have since replaced them with adjustables.
As far as the negative camber... I bet the suspension is also sagging pretty low. New springs and struts should fix the problem.
