Crankshaft sensor plug
PFA
MI
I did a major booboooooo. I broke the plug that attaches to the sensor for the crankshaft position.
Is there anywhere to get a new one? Any fix that is known? The shell of the plug is gone.
Northwestvoodoo
Vancouver Island, BC,CAN.
Did you crack it, or it fell apart? If you have the pieces, plastic "weld" it with your soldering iron. ( Don't inhale.)It will look like ****, but should hold. I have plenty more stupid ideas if this fails. I'd try it.
ThatShoGuy
michigan
are you sayin the plug at the end of the wire has a broken clip if so i used some rtv silacone on mine and had no trouble just dont get it in the part were the pins are...put it on the sides of the sensor
hawkeye18
Sorta cares
Norfolk, VA
well if all else fails, get some tab and socket wire ends, crimp them on each wire, and hook up each wire directly. It's not like you need the socket to make the connection - it just makes it a lot easier.
PFA
MI
I don't have the black plastic surround, that actually does the clipping/holding onto the sensor. The pins and internal grommet/seal are still there. My concern is of keeping water/dirt out and keeping it attached. Would RTV or silicone do this?
ALSO....is the V8list down?
Ford has a new pigtail you can get. Beware the wires are polarity sensitive.
