tweecer data logging troubles
92sho16
b00sted
Liverpool, NY
I just received my tweecer today in the future i will be running a turbo and a tune from someone else but i was trying to get a handle of the software and data logging but i cant seem to get it to data log correctly. When i set things for payload sometimes values just dont show up other times the just stick at a certain value. Am i doing something wrong? Also does anybody have a improved tune for a basically stock sho (exhaust, bbb's+ported intake)?
yamahaSHO
E85 whore
Arkansas
Are you creating a tune, pay loading, then writing to the TwEECer?
As far as an "improved" stock tune... Now is the time for YOU to learn how to do this. It won't be so forgiving with a turbo and you CAN'T count on other people to keep your car right in this area.
92sho16
b00sted
Liverpool, NY
i think i did that in that order. I dont remember i fiddled with it for awhile and still couldn't get it to work. At first i know that i tried to datalog the stock tune copied to the first switch post. so i could see where i should start. I have to say i havent gotten a wideband yet because the motor in the car now burns alot of oil and i dont want to ruin the wideband from that so im not sure how far i can tune without a wb.
yamahaSHO
E85 whore
Arkansas
Tim, what problems are you experiencing?? The only thing I see when logging something not supported on the SHO (battery voltage), it just gives random readings.
To the OP... I would just make sure you have a good install with all the updates and then try again.
92sho16
b00sted
Liverpool, NY
I think this might the issue, when i installed the bde it gave me some error about editing the registry but i didnt think much of it.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
I am not having any issues, but I remember reading on a website, or a post by Josh that there were some certain parameters that you should not check when you datalog. I just can not remember.
TT
