P1518 code
Scott 99 SHO
Haverhill, Mass
Hi To all
My 99 SHO is throwing a code P1518. My scan tool states that it is the PCM connector tach. But reading through the threads it should be the IMRC. What is the PCM connector Tach or should I just replace the IMRC that is probaly the issue at hand. Does anybody have the Ford number for the IMRC or does someone here have one to purchase,
Thanx for your help
Scott
ThatShoGuy
michigan
Hi To all
Thanx for your help
Scott
wow my car showed the same code today when i scaned my car.. prob go's along with the other codes i have..
sorry no help
bacernate
97 MONEY PIT
Denver, Colorado
It's an IMRC code according to alldata. See if the cable is broken. If so I have 1 you can have if you want to pay the shipping. The cable is about half worn but worked ok in my car until I got a tuner and removed it.
PM me if you need it. You can paypal the money for shipping.
Alan
E1 v2
crash tested
holiday inn
1518 means your IMRC didn't open properly.
It means your intake runners are all gummed up with deposits that have stopped the secondary butterflies from moving properly.
Usually, it means your IMRC cable is broken or your IMRC box plastic gear has broken.
Small chance that the IMRC is still moving and needs to be cleaned NOW to avoid having to spend !=~$200.00 on a new IMRC box after you clean the sticky intakes.
ThatShoGuy
michigan
well i assumed it was good since the last time i seen the cable it looked good well once i got around to looking at what might of happen my cable broke..
Izzmo
SHO Enthusiast
Kansas City, KS
It doesn't necessarily mean your cable is broken.
Don't take it to Ford, they will **** you over.
First check and see if your secondary butterflies open freely. Do this by removing the air filter and moving them. If they move good, then it's your cable. If they are hard to move and/or do not move at all, then it's carbon build-up in your LIM.
P1518 means the IRMC micro switch inside the IRCM module is not being made as the runners close. This is because the runners are carboned up as already said.
Best thing to do is to wire them open and forget about having secondaries. Or clean them and make it a 30k normal maintenance job.
DTCs P1518, P1537 and P1538 indicate IMRC is stuck open. DTCs P1512, P1513 and P1519 can indicate IMRC may be stuck closed. DTCs P1516 and P1517 indicate IMRC input error. DTC P1520 indicates IMRC control circuit malfunction.
Possible causes:
Cables improperly routed (binding) or seized.
Damaged/disconnected IMRC housing return springs.
Lever/shaft return stop obstructed/bent.
Lever/shaft wide open stop obstructed/bent.
IMRC lever/shaft stick/bind or disconnected.
IMRC actuator cable/gears seized.
For electric IMRC, view cable routing. Make sure cables are not binding or improperly routed. With key off, cable core wire at IMRC housing attachment must have slack and lever must contact Closed Plate Stop Screw. For ******/Tracer, view IMRC actuator lever. Make sure lever is visible. For vacuum operated IMRC systems, make sure sensor linkage is attached and secure. Lever must contact closed plate stop screw with key off. Also, make sure IMRC sensor harness connectors are attached to the proper bank. They are interchangeable. If necessary, use a breakout box to pin out the harness connectors to the corresponding electronic EC pin. Refer to the IMRC System Description in Section 1A , Intake Air and Throttle Body, for illustrations.
Note: IMRC return spring is strong. Make sure return springs operate properly and plates open and close fully.
Manually open and close IMRC plates at intake manifold (press IMRC lever down for ******/Tracer) and feel for sticking/binding.
Scott 99 SHO
Haverhill, Mass
P1518
Hi, Paul
Thank you very much for the information.
Scott
Possible causes:
It could also be because the cable is frayed just inside the IRMC box. This happened to me and was the final straw on the POS.
Staff online
