Cutting Rear Eibachs!
randy'sho
95 White MTX
High Point, NC
just confirming after researching and finding different answers! i cut one coil off the top of my front eibachs and installed them and they look great...this weekend the rears are to be installed....my questions is I do cut one off the bottom of my rear springs right???? I am just confirming before I make a mistake! Thanks Randy...ps since I cut one in the front should I do one or just half off in the rear? thanks Randy
1993MTXSHO
Its a Taurus...
Jersey
I think you cut the top coils, but don't quote me on that. Also I cut one coil out of my fronts and cut NONE out of the rear, and the car sits very evenly and looks great. So my personal opinion is if you are going to cut it, cut half out, and if you really want more, take it out and cut it again, but once its off, its off.
hawkeye18
Sorta cares
Norfolk, VA
You want to cut the dead coils... i.e. the ones that just sit on top of each other, aka the bunched up end. If you cut a coil off the live end (the other side), you will take a lot of compliance out of the ride, and it will very negatively affect your ride quality and the safety of the vehicle. Eibachs are already lowering springs; I wouldn't cut more than a coil off of them.
randy'sho
95 White MTX
High Point, NC
see this is my point exactly....some say cut the bottom of the rears and some say cut the top of the rears.....fronts are already done....i need help on the rears only......
K-Dawg
Treasure Coast, FL
Don't even cut them if you want the rear lower. Just lower the strut in the knuckle. If you cut them you are reducing your strut travel.
If you do cut them, you want to cut the coils that are wound very close together.
ty91sho
EVRYDAYHUSTLIN'
st.cloud MN
you should post up some pics when she is all done! i would like to see what the rears look like if you cut them
