new code P0402
ThatShoGuy
michigan
P0402 Exhaust Gas Recirculation Flow Excessive Detected
how to fix this one?
think its related to my evap codes?
455
443
thanks
ive been searching and using my service manual and cant seem to find info on it yet besides P0402 Exhaust Gas Recirculation Flow Excessive Detected
Diagnostic Trouble Code (DTC) P0402 indicates that Self-Test has detected EGR flow at idle.
Note: If DTC P1405 is in Continuous Memory, diagnose that first starting with HE50.
Possible causes:
EGR valve stuck open.
EGR vacuum regulator solenoid vent plugged or iced.
EVR circuit shorted to GND.
EVR circuit shorted to VREF.
Improper vacuum hose connection.
Plugged/pinched EGR Vacuum Regulator Solenoid vacuum hose.
Plugged EGR tube.
Damaged EGR Vacuum Regulator Solenoid solenoid.
Pinched/iced pressure hoses.
Damaged Differential Pressure Feedback EGR (D.P.F. EGR) sensor.
Damaged PCM.
ThatShoGuy
michigan
Possible causes:
Plugged EGR tube.
Damaged PCM.
thanks sho123 you always help me, your gonna have to teach me how to use this service manual better. that way i can figure i out my self. lol
