Downshift
WTFvolvo
Broken sho
Kissimmee, Florida
I bogg when I want to downshift and get on it. I made myself look like a tard when I first got the car trying to have some fun with a 6.0 GTO. When I downshifted I bogged out bad.
Is that normal for these cars?
bigblock
cali
a little more details would help. what gear,rpm, mph, ect..
Cocoa,Florida
no,its not.
that car has several issues that has had a few of us SHO folks down here stumped.
if its anything like it was when i drove it,it has a slight miss and is by far the slowest SHO ive even even sat in.
WTFvolvo
Broken sho
Kissimmee, Florida
no,its not.
Its pretty fast from a dead stop first through third. 4th and 5th are a little slow.
I've pretty much concluded all of the problems on this car except for this one and why it stalls out at rapid RPM drop when there is plenty of oil.
itwonder
VA
Your signature indicates open headers. Maybe your modified exhaust system is responsible for the loss in low end torque?
WTFvolvo
Broken sho
Kissimmee, Florida
Uhm.. wasn't my mod. Doesn't unrestrictive exhaust give you more torque?
Just this part of your post would have made perfect sense.
:laugh_ti::evilgrin:
sorry, couldn't resist!
LoL... They run like 13's... right? Im not saying I'd take him, I was just curious...
RiceeatingSHO
Travis R
Alabama
When I ran open Y-pipe with cats I could feel the loss in torque. not saying that's your problem but you never know.
1993MTXSHO
Its a Taurus...
Jersey
Back pressure helps tq, free exhaust helps HP. Having to free flowing of an exhaust can sometimes actually be bad. I forget what it is called but it is when part of the intake charge gets sucked right out the exhaust because it flows so well, I forget what it was I read in it a book Ted B wrote. Also having a free flowing exhaust on a car not built for it can burn exhaust valves;)
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
your problem sounds like it could also be tps related...
i dont know how its got people stumped... simple test and replace everything till its fixed.
ive just had my fair share of really weird tps problems... check the sensor and replace...
also more advice on what else to do with the tps but ill let you find that on your own
ras2433
Forced Inducted
Wap Wap
Could possibly be EGR valve or sensor!
I had the same prob. on my neon! replaced both the EGR valve/sensor and it runs great!
Cocoa,Florida
FAIL:smash:
you really should follow the advice that Chris gave you,about replacing the engine/underhood harness'
some baffon has rigged that thing up and thats the best way to get it back to normal.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
FAIL:smash:
Open headers too on that car now... The origional problem is in that harness...so until this gets replaced you will keep having issues and possibly fry another ECU or IRCM. I'd hook that exhaust back up so you don't get any excessive DB tickets or go deaf.
WTFvolvo
Broken sho
Kissimmee, Florida
Im doing exhaust very soon.
What harness are you talking about?
It needs a new IRCM harness... I have it, just need to install it... and it needs a new DIS harness, just waiting to find one. I've been PMing people about it. Other then the hand wired ECU harness, what are you talking about?
Cocoa,Florida
the IRCM harness is the "underhood harness" and the DIS harness is the "engine harness"
replace these and im thinking you'll be golden.
if your running open headers how are your o2's mounted?
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Okay, there are 3 harnesses under the hood:
1: The engine harness....connects to DIS, injectors, CPS, O2, ect... This harness stays on the engine when you pull an engine.
2: The ECU/IRCM harness....obviously connects to the computer and relay control module as well as all the other various sensors under the hood. This also mates into the body harness under the hood.
3: The body harness....feeds the underhood fuse box and goes into the car. Runs the headlights, blinkers, airbags, ect.
I have a couple spare engine harnesses right now... Did you PM any of the FL guys? Brian has one as well...
WTFvolvo
Broken sho
Kissimmee, Florida
I have PMed members for other parts that I need, but not for this.
So does the engine harness include everything? It is a hard process? Wouldn't think so... but I dont really know much about SHOs yet.
Staff online
