Has your fuel pump failed and had the same symptoms as mine? I just remembered, while cranking my C/E light dims almost to the point where it's out! Had a ABS light blinking right before it died. Anymore ideas?
can you hear the fuel pump prime when you turn the key to on?
First, how are you validating that you have fuel and spark?
Second, a dimming [ CHECK ENGINE ] Light indicates an electrical problem/short.
[deleted]
If during prove-out the CEL dims, but the other cluster lights do not, the CCRM is most likely bad. If all the cluster lights dim, then you have an eletrical problem - bad battery cables and/or connectors, bad battery, bad starter, harness short, (ICM in vehicles that have them), and/or bad ECM.
[deleted]
I performed the tests above. Everything checks out as described. What is my next step?
