broke rear tensioner
marv
chicago
I had a rear cam tensioner fail (was competely slack when I opened up valve cover) and I noticed flecks of brass in intake runners behind valves. Did I destroy my valve guides or can I put new tensioner on and it will be ok.
Storm-Chaser
Shit Louis
What makes you think it is brass ?
What is physically damaged ?
- tensioner chain
- tensioner pad only
- underside of valve cover
- steel tensioner pad under the phenolic pad
- other item(s)
:burnout:
marv
chicago
The t piece that holds the tension so the chain was hanging slack. The chain did
not break. The pieces are brass colored, I don't know if they are brass. The metal pieces (almost like dusting but a little bigger) are were the intake runners connect to the head and the seem to be in only three of the six ports.
Storm-Chaser
Shit Louis
But you still didn't answer the question:
- tensioner chain
- other item(s)
Whatever you found inside the heads and runners had to come from somewhere/something. In order for there to be "filings", the tensioner chain had to come into contact with "something", which it chewed-up/chewed-into in producing the filings. Find what was physically damaged by the tensioner failure, and most likely it is the source of the "filings" - if that's what they are.
RAYJAY
WHO ME ?
UNION DALE PA
pictures would be great at this time........
Jeff
AREA 91
Area 91
bump? What happened?
Chain tensioner?
Rod bearings?
Valve guides?
