anybody know if the liconln town cars have fn 74 brackets.. also would ther calipers/ rotors/ spindles work?
any 2001+ taurus has them
as well as the v8 continentals
or the gen 3 SHO's.........
you need 94-95 style Taurus Knuckles
then you need 94+ Taurus Calipers
99 SHO Caliper bracket
99SHO Pad
99 SHO Rotor
and you also need all the hardware off of a 99 SHO, specially the caliper to knuckle mounting bolts.... and caliper to bracket
Has what - just the FN74s, or do the calipers/ rotors/ spindles also work ? (since sho chick asked this as well)
As well what -every Continental with a V8 engine that was ever produced ?
NOT !
The calipers/ rotors/ spindles will work ?
From *ALL* 94-95 Taurus ?
Again . . . .
NOT !
Only from a 99 SHO ?
This IS incorrect - that's strike two - next time we shoot you . . . .
The caliper bracket bolts need to come from a 94-95 Taurus or Sable. There are other F*** vehicles that use the same front caliper bracket bolt, but I've not taken time to compile them all. Caliper bracket bolts from *ANY* Gen III Taurus will not work - unless you hand-cut them to match the shorter length. So if you're already pulling 94-95 spindles, you're already pulling the 94-95 caliper bracket bolts to remove the spindles . . . .
Sorry to bust your balls "dude", but if you're going to post such information, take the time to help others out, not confuse them.
:shakehd:
